[solved] Pull-down menus not showing
Posted: Mon Jul 22, 2024 12:33 pm
by BobVKnobloch
I have tried 3.30.1.0 pro version on Opensuse 15.4. The pull-downs (file menu etc) do not appear.
I have version 3.23 running under Opensuse 15.3 - OK.
Copying /opt/qcad/tree from 15.3 to 15.4 also results in a lack of pull-downs.
Any ideas? Missing library?
Best wishes,
Bob von Knobloch
Re: Pull-down menus not showing
Posted: Mon Jul 22, 2024 3:12 pm
Which package did you install (file name)?
For your system, I would recommend "QCAD Professional 3.30.1 for Linux Qt 5.14 64bit (Installer)".
Posted: Tue Jul 23, 2024 8:20 am
by BobVKnobloch
I have tried the current linux installer packages:
Professional 3.30.1-trial-linux-x86_64.run
and
Professional 3.30.1-trial-linux-qt5.14-x86_64.run
It looks like a distro problem, Menus appear OK under Opensuse 15.3 ans 15.5, but not 15.4
I'm slightly baffled.
Bob
Posted: Tue Jul 23, 2024 4:06 pm
by BobVKnobloch
Now I'm really confused.
I have several machines, but test mostly on VirtualBox images.
All 'native' machines running opensuse 15.3, 15.4 & 15.5 have the pull-down menus missing.
All virtual machines run correctly.
Bob
Posted: Tue Jul 23, 2024 5:31 pm
You might want to switch off native menus as your system likely tries (and fails) to add a menu that blends in better with your window manager.
Edit > Application Preferences (or Ctrl + ,):
Widgets > Menu Bar > Use native menubar (uncheck)
Posted: Wed Jul 24, 2024 8:37 am
by BobVKnobloch
Yes, that was it. Thanks Andrew.
