QCAD Professional - New work computer
Cristhian
Post by Cristhian » Fri Mar 14, 2025 7:38 pm
Hi, back in May 10 2022 i purchased a QCAD professional license. I have changed computers at my office and i do not have access to the installer. Is there anything i can do to get the license back and use QCAD on this new computer?
I got a copy of the invoice if that helps.
Re: QCAD Professional - New work computer
Post by CVH » Sat Mar 15, 2025 3:59 am
Probably not a copy of the original installer.
May 10 2022 would be QCAD 3.27.5, the current release is 3.32.2 (2025/02/20)
With a licence you have one year of access to your personal download page.
After that you need to renew your licence.
After about a year you should have received a mail with a reduction code.
You could also contact RibbonSoft in direct with the copy of your invoice.
But that is said to be limited to one year and and three months: Accessing Downloads / Updates
BTW: A licence is personal.
QCAD should be removed from the other computer if that is still in use.
