Dimension Scale not 1:1
Post by andrew » Wed Aug 13, 2025 8:14 am
From a QCAD user:
When I want to draw a dimension entity, QCAD pops up with a warning saying that the dimension scale is not 1:1. What can I do?
Screenshot 2025-08-13 at 09.15.37.png (28.3 KiB) Viewed 14767 times
Re: Dimension Scale not 1:1
Post by andrew » Wed Aug 13, 2025 8:18 am
The message indicates that the current dimension scale factor is not 1 or 1:1. This means that if you dimension a distance, the label of the dimension will not show the measured distance.
Let's say the scale factor is set to "2", if you dimension a distance of 100, the label will read "200" instead of "100".
You can adjust the dimension scale factor in the options toolbar shown at the top, just above the the drawing area. Set the scale to "1" or "1:1" to avoid this warning message:
Screenshot 2025-08-13 at 09.17.05.png (65.49 KiB) Viewed 14766 times
Note that this is just a warning message. You can still create a dimension entity, just with the implications outlined above.
