I cannot designate/select destination folders when:
1. Opening drawings
2. Saving drawings
3. Printing to pdf
4. Exporting to pdf
My Operating system is: Ubuntu 24.04.3 LTS running on a Dell Latitude E6545
My QCAD version: QCAD Professional Version: 3.32.3.1 (3.32.3.1)
Cannot select destination folders
hhorton
- Registered Member
- workfile2.dwg
- The QCAD dwg
- (36.1 KiB) Downloaded 117 times
- The Save As dialog box
- Save As Dialog.png (93.16 KiB) Viewed 11949 times
- The Print to PDF and Export to PDF dialog boxes
- Print Export Dialog.png (156.02 KiB) Viewed 11949 times
- The Open Drawing dialog box
- Open Drawing Dialog.png (93.47 KiB) Viewed 11949 times
Re: Cannot select destination folders
Could it be that you might have installed the flatpak?
If so, please Google "flatpak allow access to folders Ubuntu 24".
hhorton
- Registered Member
Thanks, Andrew.
I did install using Flatpak. I googled as you suggested, and I've installed Flatseal to manage Flatpak permissions. QCad now works.
The instructions I used are:
Using a Graphical Tool (Flatseal):
Flatseal provides a user-friendly graphical interface to manage Flatpak permissions. Install Flatseal.
Code: flatpak install flathub com.github.tchx84.Flatseal
Manage Permissions with Flatseal.
Launch Flatseal, select the desired Flatpak application from the list, and navigate to the "Filesystem" section. Here, you can add custom directories to grant access to, or modify other filesystem-related permissions. Remember to restart the application after making changes in Flatseal.
I've attached a screenshot of the Flatseal screen.
- Screenshot from 2025-09-27 09-03-35.png (109.76 KiB) Viewed 11679 times
