Problem with polylines
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
jvalencia
Post by jvalencia » Fri Jul 17, 2015 4:04 pm
Hi, I'm trying to join some segments and arcs into a polyline. The result is not what I expected.
Left: segments
Right: wrong polyline created
Another problem I have is when extruding polylines in Autocad. Sometimes it says that the polyline intersects with itself.
How can I solve that from Qcad to not happen anymore in Autocad?
sample.dxf
(147.04 KiB) Downloaded 255 times
Re: Problem with polylines
Post by andrew » Fri Jul 17, 2015 4:12 pm
Thanks for your report.
I cannot reproduce this (QCAD 3.9.5).
Can you please indicate what version of QCAD and what operating system you are using? Thanks.
jvalencia
Post by jvalencia » Fri Jul 17, 2015 4:42 pm
I'm using qcad pro 3.9.5 under linux, recently downloaded.
The thing is, I could join the polyline without problems a few minutes ago, but I can't anymore. Don't know what I'm doing wrong.
Check the attachment here.
I'm going to remove the config file and try on a clean environment.
[edit] It didn't work.
sample2.dxf
(150.39 KiB) Downloaded 252 times
Post by andrew » Fri Jul 17, 2015 4:52 pm
Thanks. That one is reproducible. I'll look into it.
jvalencia
Post by jvalencia » Mon Jul 20, 2015 6:51 pm
Wow fast work there! Waiting for next release :)
