PDF not centered
guido70
PDF not centered
Post by guido70 » Sun Aug 02, 2015 10:25 am
Hi, also I have problems with the pdf: even if "Click the button to center the drawing on paper" the drawing is printed centered up and down, but it is moved to the left.
Qcad version : 3.9.7
O.S. Ubuntu LTS 14.04.2
prova.pdf
(15.42 KiB) Downloaded 273 times
Re: PDF output off center
Post by andrew » Sun Aug 02, 2015 10:29 am
Guido, thanks for your report. Again, please attach the drawing file (dxf or dwg). Thanks
guido70
Post by guido70 » Sun Aug 02, 2015 10:33 am
Hi, this is the file
prova.dwg
(16.28 KiB) Downloaded 260 times
Post by andrew » Sun Aug 02, 2015 11:31 am
Looks fine here. Can you check your printer margins:
Edit > Drawing Preferences > Printing > Multi Pages
Screen Shot 2015-08-02 at 12.31.16.png (173.47 KiB) Viewed 5238 times
guido70
Re: PDF not centered
Post by guido70 » Sun Aug 02, 2015 12:04 pm
Sorry the problem persist:
look at the attachment settings for pages .
I drew a frame A4 and it is printed shifted to the left
prova.dwg
(17.03 KiB) Downloaded 247 times
prova.pdf
(16.27 KiB) Downloaded 267 times
guido70
Post by guido70 » Sun Aug 02, 2015 12:19 pm
this is the attachement for page settings
Settings .png (278.07 KiB) Viewed 5231 times
Post by andrew » Sun Aug 02, 2015 1:37 pm
OK, thanks. I've filed a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1247
Post by andrew » Sun Aug 02, 2015 6:32 pm
This should be fixed in the current 3.9.8 release.
