Running on openSUSE 13.2_64/KDE. Relatively fast, recent hardware. Plenty of RAM
Stalls at times, System Monitor shows 1 core fully engaged (one of 8 core, 13% of total CPU) for long periods.
Does QCAD not multi-thread?
I have been doing a lot of in and out on the dxf file - perhaps some garbage hanging around.
Any way to 'clean up' the file ?
Perhaps this is a good indicator - it takes QCAD 20-25 seconds to save and close, file is 4.7MB
QCAD 3.12.6.0 Sluggish at times
- Full Member
Re: QCAD 3.12.6.0 Sluggish at times
This might be autosave, storing your file every 5min or so. Check your autosave settings under Edit > Application Preferences > Load/Save > Autosave
- Full Member
I do have autosave turned on.
I'll try spreading them out to diagnose.
File is large because of embedded graphic.
Is 4.7MB a big dxf file?
Hi cmcgrath5035
How about trying 'Draftmode', might make a difference here?
- Full Member
Thanks Clive, I'll give that a try.
