QCAD 3.14.3 Crashing when opening .DWG
PeterD
Post by PeterD » Fri May 13, 2016 10:46 pm
Each time I try to open a .DWG file that was created originally in AutoCad, QCAD crashes. Also, if I click on the 'Import' button, it crashes.
Any suggestions?
Re: QCAD 3.14.3 Crashing when opening .DWG
Post by andrew » Tue May 17, 2016 7:46 am
Thanks for your report.
- indicate the operating system you are using and the version thereof
- attach or e-mail original drawing files (DXF, DWG, ...) if possible
- if there is an error message, indicate the exact message
