Version 3.7.5 has behaved erratically since upgrading to Windows 10 (from 8.1). It often freezes, sometimes crashes, takes considerably longer to execute commands, doesn't always execute. I thought I'd see others reporting such problems in the forum, but it doesn't seem to be a common situation. Any help in solving the issue will be much appreciated.
Thanks, Rob DV
QCAD 3.7.5 problems with Windows 10 upgrade (64bit)
Re: QCAD 3.7.5 problems with Windows 10 upgrade (64bit)
Thanks for your report.
I would recommend to download and test the free trial version of the latest 64bit package for Windows, to see if the problem still exists in newer QCAD versions:
http://qcad.org/archives/qcad/qcad-latest-win64.zip
By downloading and extracting the ZIP archive and not the installer, you can be sure that your current installation (DXF/DWG file associations) will be unaffected.
I will also send you an update discount coupon code, so you can update at a 30% discount if desired.
