Dear all,
I'm using QCad 3.15.2 Pro. While trying to open a dxf file I get an error message.
I have attached the dxf file and also the error message to my message.
A friend of mine managed to open the file using a free software called NanoCad:
Would you like please help.
All the best
Can not open a DXF file
- Sahir-02-05-2.dxf
- (1.36 MiB) Downloaded 155 times
- 1.JPG (22.09 KiB) Viewed 2702 times
Re: Can not open a DXF file
Hi Ilhan Gokcay,
Try this one:Ilhan Gokcay wrote:Dear all,
Thanks for submitting this file. The problem has been fixed for the next release (attempt to import erased layout).
Bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1433
Bug report at:
Thanks Andrew.
