I'm trying to open a DWG file from Drafix / Drafix Plus but QCAD refuses to open it.
DWG File from Drafix
From a QCAD user:
Re: DWG File from Drafix
Drafix DWG files are not in the DWG format that is supported by QCAD. It's an entirely different file format, which just happens to use the same three letter file extension DWG. QCAD opens files in Autocad DWG format only.
