I am using QCAD to convert dxf files into svg. I am doing this for a software where we are allowing user to import their CAD drawings. I am facing a strange problem. Some of my files are getting converted correctly but others are not. My software is using dwv2svg command from a java class. Attached are two samples files which are not getting converted correctly. I tried to open them in QCAD desktop application and they were looking fine. When I tried to export them to SVG from desktop application I was getting same behaviour.
dwg2svg conversion
dwg2svg conversion
- house.dxf
- (16.1 KiB) Downloaded 258 times
- House Floor Plan Sample.dwg
- (230.07 KiB) Downloaded 243 times
Re: dwg2svg conversion
In house.dxf, the lineweight of layer 0 is set to 0.00mm (which means as thin as possible in the CAD world).
dwg2svg translates this into a stroke-width of 0.001 in SVG (since 0 would mean invisible in the SVG world). 0.001 is still hardly visible unless you zoom in a lot.
You can either adjust the lineweight in the DXF (lineweight of layer 0) or pass a minimum lineweight to dwg2svg, e.g.:
dwg2svg -minlineweight=0.1 house.dxf
