When running the QCAD command line tools on a Linux server, an error message appears:
Fatal: QXcbConnection: Could not connect to display
QCAD Command Line Tools on a Linux Server
From a QCAD user:
Re: QCAD Command Line Tools on a Linux Server
If you are running the QCAD command line tools on a headless Linux server (i.e. a Linux server without a display, without an X11 server), you'll have to use the offscreen platform plugin (starting with Qt 5, QCAD 3.16):
You also might have to set the QT_QPA_FONTDIR environment variable to point to a directory with fonts to use:
Some fonts are included with your QCAD installation under fonts/qt:
However, you likely have more suitable fonts installed on your system unless you are running the command line tools on an embedded platform.
./dwg2pdf -platform offscreen ...
QT_QPA_FONTDIR=fonts/qt ./dwg2pdf -platform offscreen ...
