dwg2bmp is stucked when run it from java
henrykey
Post by henrykey » Tue Mar 21, 2017 5:30 pm
I am new in town and just get my QCAD. I try to use dwg2bmp to convert dwg file to bmp, actually i prefer jpg but no dwg2jpg found. dwg2bmp is run from java code and it's stucked when i do this in linux of ubuntu 14.04. It works in Windows with the same code. I don't what wrong with this. any one knows how to solve this problem?
PS. How can I disable the debugger information output when running dwg2bmp, I didn't find option to turn off this.
thanks,
Henry
Re: dwg2bmp is stucked when run it from java
Post by andrew » Tue Mar 21, 2017 5:36 pm
henrykey wrote:I try to use dwg2bmp to convert dwg file to bmp, actually i prefer jpg but no dwg2jpg found.
dwg2bmp can convert DXF or DWG drawings to many different bitmap formats, including Windows Bitmap (BMP), JPEG, PNG, GIF and TIFF. Simply use .jpeg or .jpg as file extension to output a JPEG.
henrykey wrote:dwg2bmp is run from java code and it's stucked when i do this in linux of ubuntu 14.04. It works in Windows with the same code. I don't what wrong with this. any one knows how to solve this problem?
This would depend a lot on your particular Java code. Does the same dwg2bmp command work fine when ran from the command line / terminal?
henrykey wrote:PS. How can I disable the debugger information output when running dwg2bmp, I didn't find option to turn off this.
You can stream stdout to /dev/null or simply ignore stderr.
henrykey
Post by henrykey » Wed Mar 22, 2017 11:09 am
yes, It works fine on command line of terminal with the same code. Here is the simple code:
// args= qcad-bin -no-dock-icon -no-gui -allow-multiple-instances -autostart \
// scripts/Pro/Tools/Dwg2Bmp/Dwg2Bmp.js /srv/wp/qcad/dwg2bmp -platform offscreen \
// -f -outfile=/srv/wp/2.bmp /srv/wp/2.dwg
String[] cmdB = args;
Process process = Runtime.getRuntime().exec(cmdB)
thanks
Henry
Post by andrew » Wed Mar 22, 2017 11:20 am
henrykey wrote:// args= qcad-bin -no-dock-icon -no-gui -allow-multiple-instances -autostart \
This looks OK to me.
I would say this is a problem with the Java side, not QCAD.
A quick Google search reveales:
http://www.javaworld.com/article/207127 ... won-t.html
-> Why Runtime.exec() hangs
Maybe that helps.
henrykey
Post by henrykey » Thu Mar 23, 2017 9:24 am
I already tried all the 4 ways. The only environment param passed in is LD_LIBRARY_PATH=/srv/wp/qcad. it's still suspend and got following message output at this point.
Converting
to : /srv/wp/2.bmp
