New problem with pointer on Mac
jweatherill
Post by jweatherill » Wed Apr 05, 2017 9:28 pm
I have a problem with the interface of QCAD pro (both 3.16.5 and 3.16.7) on MAC with OS El Capitan 10.11.6:
Although QCAD has always run smoothly in the past (since 2009), since a few days ago the QCAD crosshair pointer in the drawing viewport is now always covered by the "Mickey Mouse Glove" hand icon (usually used only in PAN mode).
This now makes the program practically unusable. Below is also a link to a video that further illustrates this problem:
https://goo.gl/photos/NMdYqy5Y3kPNFEj46
This maybe a problem originating from the MAC system.
Can you please offer any solutions?
Many thanks.
Best regards,
Jonathan Weatherill
Re: New problem with pointer on Mac
Post by andrew » Thu Apr 06, 2017 7:15 am
May I ask what kind of input device you are using? A mouse (type), trackpad, tablet, ...? Thanks.
Can you also please post the contents of your QCAD > About QCAD > System output?
jweatherill
Post by jweatherill » Sat Apr 08, 2017 10:23 am
Dear Andrew,
Thanks for your reply. Here are some rather strange developments:
I have always used the built-in trackpad (on a mid-2009 15" Macbookpro, since upgraded with SSD, 8GB ram, etc.). I plugged in a mouse and the problem vanished. I tried quitting and reopening Qcad, resarting the computer, but all seemed OK.
Then I opened the file I was working on (Autocad 13 dwg from a colleague) when the problem appeared. The "hand" returned. Then it went away when plugging in the mouse and didn't come back unless I reopened an old, Autodesk-sourced, file (which never gave me problems in the past, though).
Now after a few tries, the "hand" always comes back when I use the trackpad, even if I just touch the trackpad while the mouse is plugged in.
If I use the trackpad while a command is active, the hand reappears. To make it go away I have to complete or cancel the command and start a new command only using the mouse.
So this is obviously a trackpad/mouse problem, although it appears to have developed in a very erratic manner.
But I would still prefer to use the trackpad if possible. Any ideas?
Many thanks again for your kind help. Below is my Qcad system info output.
Best regards,
Jonathan
QCAD > About QCAD > System output:
Versions
QCAD version: 3.16.7.0
Date: Mar 20 2017
Qt version: 4.8.6
Compiler version: gcc 4.2.1
Build Date: Mar 20 2017
Revision: 5a6d77a454aed0a9d104eb56b1825cd84bf0a608
Architecture:
OS: Mac
OS version: Mac OS X 10.9
Locale
QCAD locale: en
Country: 225
Country name: United States
Language: 31
Language name: U.S. English
Script: 0
Script name: Default
Decimal point: 44
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: System
Arguments: /Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro
Plugins
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcaddwg.dylib
ID=DWG
License=Proprietary
Name=QCAD Pro
PurchaseURL=http://ribbonsoft.com/add-ons/qcadpro-purchase
QtVersion=4.8.6
SystemCodePage=23
Version=3.16.7 (Teigha® 3.09.1.0)
Description=Import/export support for the DXF format. Based on dxflib.
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcaddxf.dylib
ID=DXF
License=GPLv2+
Name=DXF
QtVersion=4.8.6
URL=http://www.qcad.org
Version=3.16.7 (dxflib 3.12.2.0)
Description=Integrated help browser.
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcadhelp.dylib
ID=HELP
License=Proprietary
Name=QCAD Pro
QtVersion=4.8.6
URL=http://www.ribbonsoft.com
Version=3.16.7
Description=Polygon clipping, boolean polygon operations, path offset.
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcadpolygon.dylib
ID=POLYGON
License=Proprietary
Name=QCAD Pro
QtVersion=4.8.6
Version=3.16.7
Description=QCAD Professional tools.
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcadproscripts.dylib
ID=PROTOOLS
License=Proprietary
Name=QCAD Pro
NamePostfix= Professional
QtVersion=4.8.6
Version=3.16.7
Description=Polygon triangulation.
FileName=/Applications/QCAD-Pro.app/Contents/PlugIns/libqcadtriangulation.dylib
ID=TRIANGULATION
License=Proprietary
Name=QCAD Pro
QtVersion=4.8.6
Version=3.16.7
Environment
__CF_USER_TEXT_ENCODING=0x1F5:0x0:0x0
XPC_SERVICE_NAME=org.qcad.212512
XPC_FLAGS=0x0
TMPDIR=/var/folders/nm/j0l67gyx6czchk3_zwd5mfgc0000gn/T/
PATH=/usr/bin:/bin:/usr/sbin:/sbin
LOGNAME=jweatherill
Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.9x8LfpIRRB/Render
USER=jweatherill
SHELL=/bin/bash
SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.bExZUOt4ho/Listeners
UNICODEMAP_JP=cp932
HOME=/Users/jweatherill
jweatherill
Post by jweatherill » Sat Apr 08, 2017 11:26 am
More strange developments...
With the mouse unplugged, sometimes (rarely, it seems) the hand doesn't appear in new, Qcad "native", drawings. But most of the time it does...
Any clues as to what is happening?
Thanks again,
Jonathan
P.S. Some of the "environment" codes are now different in the system info output. Although they are tmp codes, these haven't varied further in the last few times I have reopened Qcad:
Environment
XPC_FLAGS=0x0
LOGNAME=jweatherill
Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.hZSYvSMESZ/Render
USER=jweatherill
SHELL=/bin/bash
SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.gW35WIC8Bh/Listeners
UNICODEMAP_JP=cp932
Post by andrew » Mon Apr 10, 2017 8:24 am
Can you please try to uncheck:
Edit > Application Preferences > Graphics View > Navigation > Enable pan gesture
jweatherill
Post by jweatherill » Mon Apr 10, 2017 8:34 pm
How embarrassing...
...I could have sworn I had already tried that.
Thank you
