Strange Dithering Effect with DWG2BMP
Posted: Wed Dec 06, 2017 6:31 am
Using: QCAD version 3.19.1
OS: Ubuntu 17.04
I'm attempting to render a DXF file exported from Adobe Illustrator. I've been extracting data from the exported DXF file using a Python library and so far it's been very well formed with no strange proprietary weirdness. I rendered the DXF file into a PNG using the following command line (adjusted for brevity):
In my two attachments you can see the original file (original.png) and the result (qcad_render.png). At every boundary there is this strange dithering effect. To call a specific example, look at the shadow of he letter "I". it has a white ring around it that isn't present in the original. It's almost like parts of the image are too low of a resolution but the gaps got filled in with white.
Has anyone ever seen some thing like this before? Any ideas on how to fix/compensate for this?
OS: Ubuntu 17.04
dwg2bmp -quality=100 -window=9.555555555555555,9.666666666666664,4.5,6.5 -margin=0 -background=transparent -f -width=1350 -height=1950 -o output.png input.dxf
