hy
sorry for my bad english
i had a Problem with qcad
after i copy and paste anything i had an error.
anybody a idea?
Elmar
can not save after copy and paste
Re: can not save after copy and paste
qcad 3.15.
the error say: duplicate record Name object: (64)F
- Unbenannt.png (213.29 KiB) Viewed 5166 times
Please attach your DXF/DWG and indicate what part you are copying.
hy andrew
if i copy anything from another dwg or dxf into zinnpfandel.dxf
- zinnfandel.dxf
- (192.92 KiB) Downloaded 293 times
i think the dxf is chrashed
if i copy everything from this dxf into a new file ist the same.
i took now only parts from it and it works.
i hope it not chrashes again
edit: if i draw , it chrash
maybe it chrashes because if i copy from another dxf and there are the same layers?
Hi Elmar,
Don't worry to much about that! Would it be easier for you to communicate in German? We could do that too.truck wrote:sorry for my bad english
I tested zinnpfandel.dxf but I'm not able to reproduce the problem. Everything works just like expected. Please attache one of the other troublemaking dwg's or dxf's to see what happens on our end if we copy them into zinnpfandel.dxf. Thanks.truck wrote:if i copy anything from another dwg or dxf into zinnpfandel.dxf
