[solved] How can I change my keyboard layout?
orjo
Post by orjo » Wed Feb 07, 2018 10:24 pm
I just installed qcad/cam pro 3.19.2 and started to use it.
I'm running it on Ubuntu 17.10 My system keyboard layout is in azerty. My keyboard layout in Qcad is in qwerty.
How can I change this.
I already tryed to do a reinstall of qcad but the problem keeps the same.
On my desktop I have no problems. Only on my laptop.
Re: How can I change my keyboard layout?
Post by Husky » Thu Feb 08, 2018 5:10 am
Hi orjo - welcome to the QCAD Forum.
orjo wrote:On my desktop I have no problems. Only on my laptop.
You'll find the settings for the QCAD language below: Application Preferences / Language Settings / Language.
Keyboard settings which are used for the keyboard are controlled by the OS.
orjo
Post by orjo » Thu Feb 08, 2018 9:17 pm
Well there is something wrong. My OS is using the Belgian Keyboard layout .
Qcad is using the english layout ( azerty for the Belg and qwerty for English.
I tried to change the language in Qcad but that has no effect. It keeps using The qwerty layout.
What can I do to turn this arround?
Post by andrew » Fri Feb 09, 2018 3:54 pm
This is probably a bug in either Qt, Unity or a combination of the two. If you can provide additional information on how to reproduce this, I can look into it. Think of screenshots of your keyboard settings, do you use multiple layouts and switch between them, what are your locale settings (type locale in a terminal), etc.
orjo
Post by orjo » Sun Feb 11, 2018 9:57 am
It seems I have a bug on My laptop in Ubuntu 17.10. I can not set it to the regional settings I need.
I select Duct Belgian to be the standard but it keeps referring to the dutch dutch settings when I look in the settings.
I deleted the language settings for dutch started in English and after a few startup's set everything for belgium dutch but in Qcad it keeps typing with the english keyboard layout.
Does this means that ubuntu 17.10 sucks?
orjo
Post by orjo » Sun Feb 11, 2018 11:02 am
I did an other install. This time back to Ubuntu 16.04.3.
Qcad is now working as it should.
Post by Husky » Sun Feb 11, 2018 6:49 pm
orjo wrote:Qcad is now working as it should.
Great - glad to hear that!
orjo
Re: [solved] How can I change my keyboard layout?
Post by orjo » Wed Aug 24, 2022 9:30 pm
Hi, me again with the same problem.
I just installed the latest Ubuntu version 22.04.1 with all updates.
Installing my previous Qcad pro software version qcad-3.25.2-pro-linux-x86_64 I had a problem.
My system is setup with a azerty keyboard and when using qcad it is typing in qwerty.
I bought the latest version and tried to install it and it had the same problem. I did a few uninstall removed all the folders and config files but it keep having the same problem.
can any body point me in the right direction.
I just bought the online version qcad-3.27.6-pro-linux-x86_64
What are the Qt versions about?
Post by andrew » Thu Aug 25, 2022 3:13 pm
orjo: The correct download for your system is:
"QCAD Professional 3.27.6 for Linux Qt 5.14 64bit (Installer)"
orjo
Post by orjo » Thu Aug 25, 2022 7:09 pm
Thank you its working now.
guyrinf
Post by guyrinf » Tue Nov 15, 2022 12:11 pm
Could you help me? It would be appreciated.
I have the same problem but with Qcad 3.27.1 and ubuntu 22.04.1
When I write a text, the [shift] function to insert accents or symbols no longer works.
I no longer have access to: é É è È ê Ê etc.
With ubuntu 18.04 and Qcad 3.27.1 I had no problem, I had access to all these accents.
Hope I was clear enough, thanks.
guy
oliverg
Post by oliverg » Wed Jan 18, 2023 10:50 am
I am running QCAD pro 3.27.8.0 on a current Debian ("testing") Linux with the standard 64bit Linux installer (not the specific qt5 version).
For me, too, everything was fine on my desktop system whereas the keyboard layout was incorrectly set to "US" on my laptop. The only difference I noted was that I was using X11 on my desktop system due to the nvidia graphics card while using wayland with the built-in Intel graphics on the laptop. Switching from wayland to X11 on the laptop fixed the problem for me.
Since I do not necessarily need wayland on my laptop this is okay for me. However, someone should dig into this issue and find the root cause.
I can file a bug report if someone gives me a hint if this is a bug rather in Qt, Wayland or QCAD itself.
Post by andrew » Wed Jan 18, 2023 11:04 am
oliverg: On Wayland, you'd have to use the "Qt 5.14" package as indicated above.
