[solved] Block Problems
kenterm
Post by kenterm » Mon Feb 12, 2018 7:01 am
I have been using QCAD for months without any problem with Blocks. Today I must have Fat Fingered something that started it. Any of my drawings, old or new, now have the same error. Rebooting QCAD make no difference.
The Problem....
1 - I create a Block (See attachment 1).
2 - I now attempt to insert the block into the drawing and the block displays upside down Except for the text, as in Attachment 2.
3 - I then double click on the Block name in the list and it displays correctly fgor editing purposes which hints that the Block is not corrupted, only displaying incorrectly.
4 - Please Help!! Thanks.
Ken
I am using QCAD Pro 3.19.2.0 [64-bit] & W7 [64-bit].
1-2018-02-12 00_09_47-Plane Rack.dxf _ - QCAD.jpg (460.67 KiB) Viewed 605 times
2-2018-02-12 00_13_16-Plane Rack.dxf _ - QCAD.jpg (465.78 KiB) Viewed 605 times
3-2018-02-12 00_14_57-Plane Rack.dxf _ - QCAD.jpg (458.49 KiB) Viewed 605 times
Re: Block Problems
Post by Husky » Mon Feb 12, 2018 8:18 am
Hi Ken
kenterm wrote:2 - I now attempt to insert the block into the drawing and the block displays upside down Except for the text, as in Attachment 2.
Keep an eye on the option bar which pops up when you insert a block.
If the option bar doesn't pops up please activate this feature below Menu / View / Toolbars and Widgets / Toolbars / Options
kenterm
Re: Block Problems
Post by kenterm » Mon Feb 12, 2018 6:14 pm
Thanks Husky - I knew I did something but had no idea what. We learn every day. Thanks!
