I've not been able open other people's dwg files from AutoCAD. I've double checked I'm using my Pro version (see screen capture).
Today, I've tried to open a relatively simple file. The layers list suggests that the content has loaded, but there's nothing to see when I zoom to extents.
I'm embarrassed that I'm probably overlooking something obvious, but all out of ideas.
Any suggestions very welcome. Thanks in advance,
Jen
[solved] AutoCAD dwg files
Re: AutoCAD dwg files
Hi Jen,
Most likely the content is stored in a Layout Block (Block List). If not please attache the dxf/dwg to this post for further investigation. Thanks.thecurlyjen wrote:The layers list suggests that the content has loaded, but there's nothing to see when I zoom to extents.
Ah yes, there it is.
With many more blocks and variations than I'd anticipated!
Thanks again Husky,
Thanks again Husky,
You're welcome.
