[solved] 3.21.1 Tool shortcuts cannot be stored
Rantanplan7
Post by Rantanplan7 » Mon Jul 02, 2018 12:00 pm
Hi Andrew,
I cannot store anymore new settings the tool shortcuts. If put a new shortcut for example zoom window Z,W in it will work for that session but not after re-starting QCAD. As well after I have done this and go into the settings again my new shortcut is gone but will still work for that session without re-starting QCAD.
Any idea about a workaround?
Best Regards
Sven
QCAD 3.21.3 / Windows 7 Professional SP1 64-bit / 8 GB RAM, i5 2520M@2.5GHz, SSD
(former Autosketch 10 user)
Rantanplan7
Re: 3.21.1 Tool shortcuts cannot be stored
Post by Rantanplan7 » Tue Jul 03, 2018 7:50 am
Very strange. I have played around a lot, especially with editing the qcad.ini file in the sections commands and shortcuts to get my own shortcuts in but it isn't working. QCAD is simply overwriting it with invalid.
Best Regards
Sven
Rantanplan7
Post by Rantanplan7 » Tue Jul 03, 2018 7:53 am
QCAD3.ini
(80.21 KiB) Downloaded 34 times
This is my actual ini file.
Best Regards
Sven
Rantanplan7
Post by Rantanplan7 » Tue Jul 03, 2018 4:48 pm
Just tried it on an older 3.19.2 installation on a different windows 10 PC. It works, I can store new shortcuts.
Best Regards
Sven
Post by andrew » Tue Jul 03, 2018 5:06 pm
I can confirm is a bug:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1776
If you are interested in snapshot releases (unstable), you can download the latest snapshot release (3.21.1.1) from the download page (under "Snapshots)".
Post by Husky » Tue Jul 03, 2018 5:09 pm
Yep - same here!
Win10/64 - QCAD Pro 3.21.1.0 will not save changed shortcuts. :(
Older QCAD Pro Version are working flawless.
Edit: Andrew was faster ... :D
Rantanplan7
Post by Rantanplan7 » Wed Jul 04, 2018 6:23 am
Thanks Andrew and Husky (and I thought Husky's are quick ones??) to confirm this although I hoped that there is a workaround at least. So for the time being I will try to get the existing shortcuts into my mind as I don't like to go back to 3.19.2.
Best Regards
Sven
Rantanplan7
Post by Rantanplan7 » Wed Jul 04, 2018 7:07 am
If I try that, would you like to get comments on that snapshot as well? And if yes on a private message or here in the board?
Best Regards
Sven
Post by andrew » Wed Jul 04, 2018 9:02 am
Yes, please do provide feedback if possible. In the public forum but a separate topic would be fine, thanks.
Rantanplan7
Re: [solved] 3.21.1 Tool shortcuts cannot be stored
Post by Rantanplan7 » Tue Jul 10, 2018 2:33 pm
It's working fine with 3.21.2 thanks. :wink:
Best Regards
Sven
