[solved] Dimensions do not match Line size
Nate
Post by Nate » Thu Jul 05, 2018 11:47 am
Dimensions do not match line length
Re: Dimensions do not match Line size
Post by andrew » Thu Jul 05, 2018 11:49 am
Most likely the linear factor of your dimension entity is not 1 (see property editor).
If that does not solve your problem, please attach your DXF file.
Nate
Post by Nate » Thu Jul 05, 2018 11:55 am
Problem solved Thanks
Nate
Re: [solved] Dimensions do not match Line size
Post by Nate » Thu Jul 05, 2018 2:05 pm
is there a default linear factor i have to change each dimension to 1
Drawing.dxf
(99.99 KiB) Downloaded 34 times
Post by andrew » Thu Jul 05, 2018 3:05 pm
For existing dimensions:
- select all dimensions
- use property editor to change linear factor to 1
For new dimensions:
- while drawing a dimension, you can enter the linear factor in the options toolbar at the top
