Ctrl+W not closing QCAD tab
dfriasb
Post by dfriasb » Wed Jul 18, 2018 9:59 am
Dear all,
I used Ctrl+W shortcut to close QCAD tab. Since last version installation 3.21.2.0 (3.21.2), it's not working anymore. I cannot see in in the window top menu neither.
I'm running QCAD Professional 3.21.2.0 (3.21.2) in Linux Ubuntu 18.04 LTS.
dfriasb@gmail.com | davidfriasarquitecto.es
Re: Ctrl+W not closing QCAD tab
Post by andrew » Wed Jul 18, 2018 10:58 am
Could it be that you've (accidentally) installed the legacy package for older Linux distributions which uses Qt 4?
For Ubuntu 18, you should be able to use the regular Linux package instead.
dfriasb
Post by dfriasb » Wed Jul 18, 2018 5:30 pm
That's it!! Thanks a lot Andrew! :D
