See attached files.
I'm trying på put an angle dimension between two lines.
In the model it's fine (60), but in the view-port it's not, it's a totally diffent number (150).
I've tried to move to model around (UCS wise), use different lines.. nothing works.
I'm running MacOS High Sierra, v 10.13.6
I'm an old AutoCAD user who was looking for something else (cheaper) to do simple tech-drawings..
QCad looked like a good alternative...
/Carsten
Angle dimension is wrong in page-viewport
- Registered Member
- wrong-angle.pdf
- (43.26 KiB) Downloaded 306 times
- wrong-angle.dxf
- (124.17 KiB) Downloaded 302 times
Re: Angle dimension is wrong in page-viewport
The bug report for this problem is available at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1792
This has been fixed for the next release.
