Blocks not grouped
ljbuller
Blocks not grouped
Post by ljbuller » Fri May 31, 2019 3:32 am
using QCAD pro 3.22.0 on one computer import treats imported files as blocks. they show up in the block list and are grouped. On another computer when I use the file - import command, files import exploded, and they do not show up on the block list.
import as block.dxf
(229.88 KiB) Downloaded 423 times
Re: Blocks not grouped
Post by Husky » Fri May 31, 2019 4:11 am
Please make sure you are using the same settings within the import option bar.
ljbuller
Post by ljbuller » Sun Jun 02, 2019 3:13 am
Ah there it is... thanks
