zoomauto bug?
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
RogerMcCarty
zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 4:36 am
The zoomauto command considers objects on hidden layers to determine new drawing size. Normal behavior or bug? Seems a bug to me.
QCAD Professional
Version:
3.22.1.0 (3.22.1)
Internet:
QCAD.org
Build Date:
May 21 2019
Revision:
46d6499
Qt Version:
5.10.1
Architecture:
x86_64 [macOS 10.14.5]
Compiler:
Clang 10.0.0
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 5:23 am
Can't reproduce that behavior on a Win10 installation. Can you post an example drawing which shows this effect? Thanks.
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 5:54 am
Hope this is clear.
1. Load the drawing and Zoomout.
2. Do zoomauto, notice the awkward amount of free space below visible objects.
3. Unhide the layer "board2" and see the reason zoom was not greater.
Screen Shot 2019-06-06 at 9.47.05 PM.png (969.98 KiB) Viewed 6624 times
Screen Shot 2019-06-06 at 9.47.09 PM.png (1.04 MiB) Viewed 6624 times
Screen Shot 2019-06-06 at 9.47.16 PM.png (1013.99 KiB) Viewed 6624 times
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 5:59 am
I suppose I should show effect of deleting the board2 layer
1. delete the layer
2. zoomauto again, notice the zoom is now greater.
The final screen capture shows the zoom I expected would have happened initially.
Screen Shot 2019-06-06 at 9.57.01 PM.png (985.9 KiB) Viewed 6622 times
Screen Shot 2019-06-06 at 9.57.05 PM.png (1.02 MiB) Viewed 6622 times
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 6:08 am
Hope this is clear.
It was already clear but without the dxf/dwg there is no chance for us to reproduce the issue.
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 6:14 am
Didn't think you would expect me to post a file on the public forum.
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 7:31 am
If a drawing is confidential please feel free to use the PM function. Do you want me to delete it?
Question: Is this drawing entirely done with QCAD? Layer 0 / block t-trak-balloon-loop v4 behave weird.
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 4:39 pm
Yes and Yes.
I see the file has been downloaded 3 times.
Can you please explain "behave weird"? How do I reproduce that? How do I correct it?
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 7:16 pm
Honestly - I don't know. I think you are right that invisible layer are also used for Auto Zoom but I can't reproduce that with a new drawing. It is only with your drawing. Andrew should have a look at this and I'm sure he can help you more than me.
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 8:38 pm
OK, I understand although I have no idea how to contact him.
Since you described the behavior as weird, I am curious what symptoms you observed. Are these similar to the zoomauto issue?
I suppose I could simply re-draw that portion, but since I don't know what I am trying to fix I would have no idea if I succeeded.
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 8:48 pm
I can contact him for you if you allow me to share your drawing with him.
RogerMcCarty
Re: zoomauto bug?
Post by RogerMcCarty » Fri Jun 07, 2019 9:16 pm
Yes please contact, feel free to share drawing. Thanks!
Re: zoomauto bug?
Post by Husky » Fri Jun 07, 2019 9:30 pm
Done! :wink:
Re: zoomauto bug?
Post by andrew » Mon Jun 10, 2019 9:41 am
