dwg2svg.bat on win64 3.22.1 version
sschneider
Post by sschneider » Wed Sep 04, 2019 5:42 pm
I'm a QCAD Pro user with such an installation on my windows system. I would like to use the batch command line tool dwg2svg.bat but I don't have the scripts\Pro\Tools\Dwg2Svg\ directory in my installation in this version .
Where could I find this add on ?
Thank you,
best regards,
Sebastien.
Re: dwg2svg.bat on win64 3.22.1 version
Post by Husky » Wed Sep 04, 2019 6:16 pm
You'll find it in the main qcad folder below C:\Program Files\qcad-3.23.0-pro-win64
Post by andrew » Wed Sep 04, 2019 7:17 pm
These files are compiled into plugins (DLLs) and loaded at start.
sschneider
Post by sschneider » Wed Sep 04, 2019 10:28 pm
Ok, thank you very much, setting the path fix the problem and I can now launch the batch file to convert my file.
However, I would like to change some options used for the convert process, or update the dwg2svg code to add features, this script is not in the qlab github repository. Do you know if it's possible to find the source code for these Pro/Tools ECMAScripts somewhere ?
Thank you !
Sebastien
Post by andrew » Thu Sep 05, 2019 7:50 am
No, these command line tools are not open source. It would also very likely be of little help since Dwg2Svg.js only handles the command line arguments (user input). The actual SVG export is done in separate SVG exporter scripts (all part of QCAD Professional, proprietary). Can you provide more details as to what kind of options or features you are trying to add?
sschneider
Post by sschneider » Thu Sep 05, 2019 2:59 pm
Ok thank you Andrew,
for instance I would like to set the same kind of options as the one we have in the UI in the advanced SVG export, for instance export dot as circle (or cross) and specify the circle radius (or cross size).
In the Dwg2Svg process, I loose the DXF dot data..
thank you again for your support and your help
kind regards,
Sebastien.
Post by andrew » Thu Sep 05, 2019 4:04 pm
You can use the command line switches:
-circle=CR
or
-cross=CS
To export points as circles or crosses with the given size (CR or CS).
Please refer also to the usage information (dwg2svg.bat -h) or online at:
https://qcad.org/en/products/qcad-comma ... ls#dwg2svg
sschneider
Post by sschneider » Thu Sep 05, 2019 4:36 pm
Oh.... thank you Andrew for your time,
and sorry for not having read the documentation before, I'll try to do better next time !
Kind regards
