Poly with widths & Arc segment > 180 Rendering faulty
Post by CVH » Tue Dec 31, 2019 7:21 am
Arc segments off Polylines with widths larger then 180 degrees are rendered faulty.
As is the explosion of such.
The Arc width reduces to zero at the 180 degree marker.
I understand the corner that the math did cut.
Included: example dxf with solution. 8)
Cheers, :P
PolyWidthErrLargeArc.dxf
(113.14 KiB) Downloaded 150 times
Re: Poly with widths & Arc segment > 180 Rendering faulty
Post by andrew » Tue Jan 07, 2020 2:25 pm
