Menus not working in fullscreen mode ?
Jph
Post by Jph » Sun May 24, 2020 2:16 pm
Hello all and a very good day to you.
Name here is Joe, new user to QCAD so be gentle. :D :shock:
Question please ?
QCAD/CAM Version: 3.24.3.0 (3.24.3) 64bit
OS Windows 8.1 64bit - fully up to date.
When entering full screen mode - either by using F11 (standard Windows shortcut) - or typing fullscreen in command box in QCAD, the menus are there, but do not function at all. No drop down lists.
Please advise ?
Joe
menu issue QCAD_CAM.jpg (143.45 KiB) Viewed 630 times
Re: Menus not working in fullscreen mode ?
Post by Husky » Sun May 24, 2020 5:49 pm
yes - I can confirm that and filled a bug report for you. Thanks for reporting this.
https://www.qcad.org/bugtracker/index.p ... &sort=desc
RandallG
Post by RandallG » Sun May 24, 2020 7:07 pm
Just as info.......Using Windows 10 Pro Version 1909 64bit with Qcad Pro version 3.24.3.0 works ok.
Post by Husky » Sun May 24, 2020 7:10 pm
Topic moved to QCAD/CAM
Post by andrew » Mon May 25, 2020 8:09 am
Unfortunately, I cannot reproduce with either QCAD Professional or QCAD/CAM on Windows 10, 64bit.
Post by Husky » Mon May 25, 2020 8:53 am
Ok, I see we have to make it more interesting for you. :D :D :D
QCAD Pro works fine. The issue is with QCAD/CAM.
To show you what is going on I recorded a screen video. During the recording the issue was easy to reproduce. F11 = Menu not working!
Then I checked the recording - every pull down was visible and assumedly working ... e_surprised e_surprised e_surprised
What means ..... it looks like the drop down list doesn't opens on top of the application.
Here my proof that I can't proof it .... :roll:
Post by andrew » Mon May 25, 2020 9:01 am
Sounds like a Qt issue, possibly related to OpenGL / Windows Drivers, etc.
One possible solution might be to remove the OpenGL plugin:
plugins/qcadgles3d.dll
This will also remove the 3D simulation widget but otherwise does not affect QCAD/CAM.
Jph
Post by Jph » Mon May 25, 2020 3:17 pm
Hello guys and thank you for the help with this.
I love Husky's 'proof that he can't prove it' lol :D I laughed out loud at that.
I can confirm that, with the appropriate DLL renamed the menus now appear.
Hopefully the issue can be resolved at some point.
Thanks again.
Joe :wink: :wink:
Jph
Post by Jph » Mon May 25, 2020 3:50 pm
Just out of interest, I tested in on my Win 10 Box - as opposed to the laptop.
Same issue. (win 10 64) . The commonality is they both use the processor integrated Intel graphics.
It doesn't seem to be a windows issue. I would suspect the graphics driver. in relation to QT or OGL ?
I have a couple of RTX cards, a 2080ti and a 2070 super that are going in the flightsim rigs. I can test on them when I get around to assembling them.
It may be an issue with Intel's drivers. They are both 4000 series integrated gpus. . the laptop is the HD4000 series GPU and the Win 10 box is the HD4600 GPU.
there was a release of a 4000 series driver update a few days ago - mainly for bug fixes it appear. I just installed that and no difference.
Hope that helps fault finding.
Joe
Post by Husky » Mon May 25, 2020 9:19 pm
Additional observation:
I run a few programs on my Win10/64 which are displaying smaller windows on top of every other opened program. That is by design and what ever I do they have to stay on top. Even F11 used at any other program will not change that.
Except this particular QCAD/CAM version! It will force ALL not QCAD/CAM related "on top windows" to disappear in the background. Hope this info helps a bit ...
Jph
Post by Jph » Tue May 26, 2020 11:51 am
Hi Husky
Out of interest, what GPU are you using please ?
Joe.
Jph
Post by Jph » Tue May 26, 2020 12:45 pm
Hi Andrew and Husky.
More info that may help.
QCAD/CAM tested on Intel HD4000, Intel HD4600 and Intel® HD Graphics for Intel Atom® Processor Z3700 Series. The problem occurs on all.
Here is - what I hope - is an informative OpenGL diagnostic report using the excellent GPU_Caps_Viewer_1.44.3.1
Joe
Joe HD 4000 gpu_caps_viewer_report.txt
(28.31 KiB) Downloaded 18 times
Post by Husky » Tue May 26, 2020 6:35 pm
Hi Husky
Joe.
Nothing fancy ... :wink:
Intel HD Graphics 520
Jph
Post by Jph » Tue May 26, 2020 6:51 pm
Thanks,
Would appear to be related to intel integrated gpu. Hopefully the file attached regarding the OGLdata dump (perhaps a data 'dump' doesn't quite have the same meaning in your neck of the wood huh ?) haha. :D
Return to “QCAD/CAM”
