Hi All
This only happens with QCAD/CAM , QCAD Pro Works Fine any ideas?
Access is Denied [ SOLVED ]
- Access is denied.jpg (93.94 KiB) Viewed 3658 times
Re: Access is Denied
Hmmm
It's now happening with both? I might try restarting my pc,
and maybe reinstall..
Re: Access is Denied [ Solved ]
IT WAS AVAST - BLOCKING QCAD...
Re: Access is Denied [ SOLVED ]
Hi, John.
Somewhere mentioned inside the forum ...
Updates and Snapshots come at that rate Andrew can't get them validated in time by every Antivirus App.
You have to add an exclusion yourself.
Hi CVH
I already did, that's why I marked this post [ SOLVED ]
I posted it was AVAST antivirus that caused the issue so others could see...
'Solved how' is also important.John Hyslop wrote: ↑Sat Aug 08, 2020 12:52 pmI already did, that's why I marked this post [ SOLVED ]
I said the virus software was causing the
problem..anyone with half a brain would know
to add the exception...
Enough said don't turn this into more than it
is...
Regards
is...
Regards
