I'm using QCAD Version 3.25.1.0 (3.25.1) in MAC OS 10.15.6
When I import a dwg file, all the block attributes are not displayed : I would like to know if this feature is not supported by QCAD or if this is just a question of setting somewhere...
How it should look like :
How it looks :
Attributes :
DWG Import : bloc attributes not displayed
Re: DWG Import : bloc attributes not displayed
Block attributes are supported (ATTRIB entity and ATTDEF entity).
However, this looks like something else. If you can attach your file, I can tell you more.
Hello Andrew,
Thank you for your help !
Here is the file :
Here is the file :
Thanks. These are not regular block attributes. My best guess is that this file was produced with a software that extends the DXF/DWG format. Some kind of add-on or extension to a CAD product.
I'm afraid, this is not something QCAD will be able to support.
What a pity ! Thank you anyway Andrew for for help !
