Break out Manual issue
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
mvf
Post by mvf » Thu Nov 12, 2020 3:38 pm
I am running the latest QCAD Pro, 3.25.2.0 64-bit on Windows 7.
Could be a bug as it seems to show the same behaviour as viewtopic.php?f=32&t=4776 but I thought I'd check here in case I'm missing something obvious. I'm trying to remove part of a polyline as indicated in the attached. I can enter the first break point but not the second.
Break out Manual.dxf
(102.2 KiB) Downloaded 127 times
Re: Break out Manual issue
Post by andrew » Thu Nov 12, 2020 4:07 pm
Post by CVH » Tue Dec 22, 2020 9:08 am
Version 3.25.2.7:
Second reference is operational.
Although, the larger part is removed.
