[solved] Stretch block (not all together)
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
pascal_b
Post by pascal_b » Mon Dec 14, 2020 6:27 pm
I have some trouble when streching an area containing a block : if the 0,0 of the main drawing in not included in the stretching area, only a part (the tag here) of the block is moved. When the 0,0 is in the stretching area, all is moving togther (which is the expoected "normal" behavior).
Thanks in advance for your help.
test_stretch_block_stretch_wo_00.dxf
after stretch - 0,0 not included in the stretch area
(104.35 KiB) Downloaded 92 times
test_stretch_block_stretch_with_00.dxf
after stretch - 0,0 included in the stretch area
(104.36 KiB) Downloaded 85 times
test_stretch_block.dxf
base case
(104.36 KiB) Downloaded 88 times
Re: Stretch block (not all together)
Post by Husky » Mon Dec 14, 2020 7:40 pm
Yes, reproducible. Thanks for the report.
Somehow the combination Block + Attribute doesn't works properly. It already starts with creating a block which contains a attribute ...
Would be nice if Andrew finds the time to have a look at this. :wink:
Post by andrew » Mon Dec 14, 2020 9:12 pm
