I have some trouble when streching an area containing a block : if the 0,0 of the main drawing in not included in the stretching area, only a part (the tag here) of the block is moved. When the 0,0 is in the stretching area, all is moving togther (which is the expoected "normal" behavior).
Thanks in advance for your help.
[solved] Stretch block (not all together)
- test_stretch_block_stretch_wo_00.dxf
- after stretch - 0,0 not included in the stretch area
- (104.35 KiB) Downloaded 356 times
- test_stretch_block_stretch_with_00.dxf
- after stretch - 0,0 included in the stretch area
- (104.36 KiB) Downloaded 360 times
- test_stretch_block.dxf
- base case
- (104.36 KiB) Downloaded 342 times
Re: Stretch block (not all together)
Yes, reproducible. Thanks for the report.
Somehow the combination Block + Attribute doesn't works properly. It already starts with creating a block which contains a attribute ...
Would be nice if Andrew finds the time to have a look at this.
