Following the ebook. I can't make layer linetypes work (see snip). All linetypes stay solid, whatever is set in layer attributes.
Looked through forums but still stumped.
Layer Linetype [Solved]
- Lines.dxf
- (100.46 KiB) Downloaded 309 times
- Windows version.png (26.7 KiB) Viewed 2791 times
- QCad version.png (63.05 KiB) Viewed 2791 times
- Layer Line Attribute (Always solid).png (18.94 KiB) Viewed 2791 times
Re: Layer Linetype
Did you switch to the Screen Based Linetype mode?
Menu / View / Screen Based Linetypes = activated
Re: Layer Linetype
Sorted thank you. But I had to use the button on the top row to get it started. View-Screen based linetypes had no effect. After using the button, the style now toggles with View-Screen based linetypes.
