[SOLVED] No snap at the block array
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
dmitpon
Post by dmitpon » Sun Mar 14, 2021 10:54 am
Hi, I have a problem with a block array. Snapping works only at the zero point of coordinates.
(Windows 10)
test_bloks_array_snapping.dxf
(101.13 KiB) Downloaded 102 times
2021-03-14_14-32-00 (2).png (156.28 KiB) Viewed 1787 times
Re: No snap at the block array
Post by andrew » Mon Mar 15, 2021 9:09 am
dmitpon
Re: [SOLVED] No snap at the block array
Post by dmitpon » Fri Apr 16, 2021 7:10 am
The bug was fixed in release 3.26.2.
