dwgmapconvert: Global Width property is dropped
bumsik-angelswing
Post by bumsik-angelswing » Fri Apr 02, 2021 3:15 am
Hi, we are using your Pro product (qcad-3.26.1-pro-linux-x86_64) on Ubuntu 20.04 LTS.
We noticed that dwgmapconvert drops Global Width property from original Polylines.
$ ~/opt/qcad-3.26.1-pro-linux-x86_64/dwgmapconvert \
	-platform offscreen \
	-crs-in="EPSG:5186" \
	-crs-out="EPSG:3857" \
	-o test_reprojects.dxf \
	-f \
	test.dxf
test.dxf
Original DXF file
(290.56 KiB) Downloaded 431 times
test_reprojects.dxf
Reprojected DXF file
(292.58 KiB) Downloaded 440 times
We run the above command to convert the CRS. And we attach screenshot for the same DXF files.
Original DXF file screenshot
Reprojected DXF file screenshot
As you can see, the original polylines gets thin because they lost Global Width properties.
Is there any options to preserve Global Width?
Thanks!
Re: dwgmapconvert: Global Width property is dropped
Post by andrew » Tue Apr 06, 2021 7:16 am
Polylines can have individual start and end widths for each segment. This is currently not supported for projection as the outline of the filled polyline would have to be projected for an accurate result.
However, this particular use case with a fixed width throughout the whole polyline will be supported in the next version:
https://qcad.org/changelog
bumsik-angelswing
Post by bumsik-angelswing » Thu Apr 08, 2021 10:17 am
This is very cool! Thanks for response :) !
