Can|t select any path from DXF file. [solved]
martblek
Post by martblek » Fri Jun 18, 2021 5:21 pm
I can't select any contour or all objects in the dxf file.
QCad freezes and after a while SIGKILL.
Linux Manjaro,
QCadCamPro 3.26.4 Qt5.14.
In the legacy version for QT4 the file doesn't even load crashes right away with
qcadcam-3.26.4-pro-linux-qt4-x86_64 / qcad-bin: symbol lookup error: /home/martin/Programy/qcadcam-3.26.4-pro-linux-qt4-x86_64/plugins/libqcaddwg.so: undefined symbol: newCurve
QCAD has unexpectedly quit.
simple file attached.
flower.dxf
(119.04 KiB) Downloaded 655 times
Edit:
After converting file to R32 version problem solved.
Re: Can|t select any path from DXF file.
Post by CVH » Fri Jun 18, 2021 5:38 pm
QCAD PRO win-installer
Version: 3.26.2.0 (3.26.2)
Build Date: Apr 13 2021
Revision: 57092ea
Qt Version: 5.13.2
Architecture: i386
file R15 ... No problem with double clicking any contour ...
Splines are not QCAD native ...
martblek
Re: Can|t select any path from DXF file. [solved]
Post by martblek » Fri Jun 18, 2021 5:54 pm
all the R15 version files I tried do not work.
I need to convert them to at least the R18 version to work.
Linux Manjaro
Version: 3.26.4.0 (3.26.4)
Internet: QCAD.org
Build Date: Jun 4 2021
Revision: 0bb4334
Qt Version: 5.14.2
Architecture: x86_64
Compiler: gcc 5.4.0
martblek
Post by martblek » Fri Jun 18, 2021 5:59 pm
Snapshot version works fine.
Version: 3.25.2.13 (3.25.2.13)
Internet: QCAD.org
Build Date: Feb 12 2021
Revision: cad2d36
Qt Version: 5.8.0
Compiler: gcc 4.8.1
Post by andrew » Fri Jun 18, 2021 8:10 pm
Thanks, looks like another problem with OpenDesign and splines of that certain type (not created in QCAD).
I will report the problem to OpenDesign.
Exporting to an older format likely converted the spline somehow.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2252
