[Solved]Error viewing file
Hi all! I'm new, I've bought the professional version of qcad to open the file you see in attachments, but I cannot view all the measures and the lines appear strange.
Can you please check what's happening?
In the png file you can see a part of the dwg opened with Autocad Trueview with correct lines and measure view
EDIT: I'm on windows 10 64bit, last qcad stable version
- Immagine 2021-08-02 143247.png (22.62 KiB) Viewed 6533 times
- piante prime piazze la febbre.dwg
- (106.41 KiB) Downloaded 344 times
- Active Member
Re: Error viewing file
Hi
The problem si that the font is too small compared to how big is the drawing...
Considering how large is your drawing, I would try this GENERAL setting:
Modifica - >preferenze disegno - > Quota -> Impostazioni quota - > Fattore di Scala = 500
IF your want to act on a single quote, just select properties, and change "Scala"
BR
PS
@ Andrew Mustun
Just an idea ....
How is Autocad choosing (right) how big the font should be as default ?
Maybe could exist some empirical relation between how big is the drawing and how big needs to be the font ...
BR
PS
@ Andrew Mustun
Just an idea ....
Hi Giuliano, thank you for your answer, but it's not only a problem of dimension quota.. You can see I've red lines all over the drawing (instead they are more precise on autocad viewer)
EDIT: The lines that have a specific angle have the extension of the measure lines too long.
- Immagine 2021-08-02 151555.png (10.97 KiB) Viewed 6525 times
Please attache the dwg to your post. Thanks.
in the first post you can see the dwg file
Sorry - I missed that ...
The dwg is not a plain 2D drawing. It has also 3D features especially at the dims. QCAD is a 2D only CAD program and can't handle 3D features.
The Autocad Trueview viewer is able to read 2D AND 3D.
But if I recreate the measure inside qcad, the view is the same... The lines are too far from the measured lines
Try to flatten the drawing to 2D.
Menu / Misc / Modify / Flatten Drawing to 2D
Thank you. In this way I can recreate the measure.. how did you know it wasn't a 2d drawing?
[Solved]Re: Error viewing file
Ok! Thank you
