I am not sure, is it a bug or did I overlook something, but I noticed that in a layout the value ( ! ) of „dimension ordinate“ is scaled with the scale factor of a viewport. Sometimes in a drawing it is clearer to use dimension ordinate instead of dimension baseline and requires less space, e.g. boreholes in furniture … But with this behavior it is not really usable. ( QCAD Professional 3.26.0.0 and older, Win10 ) Attached a simple example, notice the layout. Thanks for an answer,
regards.
dimension ordinate
dimension ordinate
- Dimension Ordinate.dxf
- (138.79 KiB) Downloaded 308 times
Re: dimension ordinate
Confirmed bug. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2270
