Status Bar disabled at startup
Relic
Post by Relic » Fri Nov 26, 2021 5:00 pm
QCAD-Pro writes the preference
StatusBar = false
no matter what I set it to. The menu View > Status Bar remains always unchecked.
Filed bug report https://qcad.org/bugtracker/index.php?d ... sk_id=2319
Massimo
QCAD Professional
Version: 3.26.4.13 (3.26.4.13)
Internet: QCAD.org
Build Date: Nov 18 2021
Revision: fbb9f37
Qt Version: 5.10.1
Architecture: x86_64
Compiler: Clang 8.0.0
Nome modello: iMac
Identificatore modello: iMac12,1
Nome processore: Intel Core i5
Velocità processore: 2,5 GHz Numero di processori: 1
Numero totale di Core: 4
Cache L2 (per Core): 256 KB
Cache L3: 6 MB Memoria: 16 GB Versione Boot ROM: 87.0.0.0.0
Versione SMC (sistema): 1.71f22
Re: Status Bar disabled at startup
Post by John Hyslop » Sun Nov 28, 2021 8:28 pm
Hi Relic
This is not a fix it's a kind of hack/work around if you don't use recent files options..
Set ini to true then make it read only..
Make sure you have qcad setup as you like before you lock the ini file..
Then when a fix becomes available change it back to read/write..
Relic
Post by Relic » Sun Nov 28, 2021 10:02 pm
Hi John,
that's a nice workaround :D :D :D The only drawback of making the ini file read only is that the list of recent files is not updated, this is important to me so for the moment I will leave the preferences read/write.
