				dwg file crashes QCAD
				Posted: Sun Dec 19, 2021 5:34 pm
				by GrowMate
				Windows 20H2  (OS Build 19042.1415) QCAD 3.27.1.0 (3.27.1) (Just downloaded)
I get a 'black' screen when attempting to open this file and QCAD then crashes. May this be due to the inclusion of hatches with gradiented solid files?
File attached
				Re: dwg file crashes QCAD
				Posted: Sun Dec 19, 2021 6:24 pm
				by petevick
				Similar using Linux, Qcad hangs then an error opening TECNOFLEX symbol library.dwg message. I'd have to guess the gradient fills are the culprit.
				Posted: Sun Dec 19, 2021 6:36 pm
				by CVH
No problems whatever Win7 32 bit QCAD Pro 2.27.0 HDD
File opens in about 1/2 second among 4 other that were open.
				Posted: Sun Dec 19, 2021 10:47 pm
				by lphilpot
				For what it's worth, it opened without complaint on my Xubuntu Linux 18.04 LTS
Version: 3.27.0.0 (3.27.0)
Internet: QCAD.org
Build Date: Nov 30 2021
Revision: 62c65de
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
Could it be something with 3.27.1?
				Posted: Sun Dec 19, 2021 11:49 pm
				lphilpot wrote: ↑Sun Dec 19, 2021 10:47 pm
Yes I assume you are right!
I opened it with 3.26.0 -> no problems
I tried then to open it with 3.27.1 -> QCAD -> no response -> Win10 system -> no response! Reboot the System was the only way back to normal ...
GrowMate wrote: ↑Sun Dec 19, 2021 5:34 pm
At least something is wrong with two hatches. I deleted both and it runs now on 3.27.1 without any problems ...
The cleaned dwg:
I'll file a bug report ...
... Done!
https://www.qcad.org/bugtracker/index.p ... sk_id=2325
				Posted: Tue Dec 21, 2021 10:52 pm
				by SergeyCVS
				Hello!
I purchased QCAD (version 3.27.1.0 (3.27.1) with idea to move from Autocad. I installed it in 64-bit Ubuntu 20.04.3 LTS.
I understand, that probably not all Autocad version files can be open, that's why I saved one small job in dwg format 2010, 2007, 2004, 2000 and dfx format 2007 and 2004.
I have trial to open them and to import them either from folder or from opened QCAD.
The result was the same - Qcad started to load then suddenly automatically closed.
Please help me and explain, what can I do to open my previous autocad works.
Thank you in advance.
				Posted: Tue Dec 21, 2021 10:56 pm
				SergeyCVS: Please open a new topic and attach your drawing file (see forum rules at the top).
				Posted: Tue Dec 21, 2021 11:09 pm
				by SergeyCVS
				already done
