Maybe Memory problem with new version
MaxCap_54
Post by MaxCap_54 » Tue Apr 26, 2022 2:24 pm
I use MAcBook air with laest Monterey version
Today I've just installed the new Qcad-pro version the 3.27.2.0 (3.27.2).
When I use a paper space and add a new layout window if I try to move the added window in the paper space Qcad go to loop and doesn't respond more, so the only thing I can do is to force quit..
How can I restore precedent version ?
How can I solve this bug ?
Re: Maybe Memory problem with new version
Post by andrew » Tue Apr 26, 2022 2:32 pm
I cannot reproduce this problem here. Please attach your drawing file and indicate how you proceed. The more details you provide the more likely we can help, thanks.
QwiqDraw
Post by QwiqDraw » Wed Apr 27, 2022 2:47 am
Andrew:
If I understand MaxCap_54's issue correctly, I have started having the same issue after the update to 3.27.2.0 (3.27.2).
With the previous version, I have been working with multiple sheets for quite some time that contain numerous viewports without issue.
The issue:
If I select a viewport in paper space, then try to use the move command, selecting any of the 4 corner reference points to move the viewport or select the viewport and grab it to move it, within paper space, Qcad freezes and I must force quit. I did not have this issue in the previous version.
If I use the viewport reference points that are inside the viewport to move the viewport or move the contents of the viewport, it works fine.
If I resize the view port using the corner reference points, it works fine.
It is only when trying to move the viewport with the four corner reference points that it freezes.
I have attached a very simple file that exhibits this issue for me. I truly believe it is something in the update causing this.
Thank you
Mark
My iMac system: System Version: macOS 12.3.1 (21E258)
Model Name: iMac
Model Identifier: iMac19,1
Processor Name: 6-Core Intel Core i5
Processor Speed: 3 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 9 MB
Memory: 40 GB
System Firmware Version: 1731.100.125.0.0
OS Loader Version: 540.100.7~23
SMC Version (system): 2.46f12
QwiqDraw
Post by QwiqDraw » Wed Apr 27, 2022 2:51 am
Here is the file.
Test Viewport Issue-iMac.dxf
(98.6 KiB) Downloaded 199 times
Post by andrew » Wed Apr 27, 2022 8:41 am
Thanks for this detailed report. This helped me to track it down quickly and fix it for the next release (shortly):
https://www.qcad.org/bugtracker/index.p ... sk_id=2355
