Hello
The quick SVG export draws the correct shape.
The advanced SVG export with "Preserve Geometry" causes the top arc to flip down.
using qcad-3.27.6-pro-linux-x86_64
SVG export issue
SVG export issue
- test.dxf
- (103.71 KiB) Downloaded 217 times
- test_quick.svg
- (5 KiB) Downloaded 240 times
- test_preserve.svg
- (3.18 KiB) Downloaded 247 times
Re: SVG export issue
Thanks. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2373
