After creating a line with the Polyline Tool, I set the start and end width e.g 0.6. I save and close the file. But when I reopen the file the line has lost its set width. I have other polylines in the same drawing however that do keep their set width.
What could I be doing wrong?
Win 11
QCAD Pro 3.27.9.0
Polyline Tool Issue
Polyline Tool Issue
- polyline.png (153.47 KiB) Viewed 2261 times
Re: Polyline Tool Issue
Please attach your drawing file, so we can try to reproduce the issue.
PM sent, thank you
Thanks. I can confirm the problem.
As a workaround, please set the property "Global Width" instead which simply changes the start- and end width of all vertices of the polyline. This seems to stick. Please confirm.
The workaround appears to be working. Thank you, Andrew.
