I have inverted colors on left TOOL bar and I can't find a way to change that.
I also have inverted funktion in the Layer List. When i toggle the eye to invisible the layer becomes visible and when i toggle the layer to visible the layer becomes invisible.
Is there a way to fix this.
I'm using a MAC Mini M2 2023 and Version: 3.28.0.0 arm64.
[solved] Inverted colors and inverted funktion
- Skärmavbild 2023-03-29 kl. 16.57.13.jpg (74.06 KiB) Viewed 3199 times
- Skärmavbild 2023-03-29 kl. 16.57.01.jpg (46.88 KiB) Viewed 3199 times
Re: Inverted colors and inverted funktion
Please reset your QCAD configuration:
Thank you for fast reply.
I have done that.
Could not find "library_3_0_0_9.db"
No change. Still the same.
I have done that.
It looks like QCAD detects the dark mode while your Mac is in light mode. Unfortunately, I cannot reproduce the problem here.
What is your macOS version?
Can you try switching to dark mode and back to light mode?
Thanks for the advice.
Switching to dark mode and back to light mode solved it.
I'm on Mac OS Ventura 13.3
Great, thanks for letting me know.
