Hi good peoples of Qcad,
While prior last month it was working like a breeze, since then without explanations, all the files takes about 1 o 2 minutes to open and it is the same between actions, saving and closing :
Actual config :
Windows 11 pro 22h2 (up to date on all accounts, system and drivers)
11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz
8 Gigs of ram
Nvme SSD
Qcad qcad-3.28.1-pro-win64
I am a bit puzzled about this, I have parsed the forum and try/reset setting with no luck.
Thank you for your help.
Slow to open and to work
- DUFOURD_ECOFLO-6EH.dwg
- (74.13 KiB) Downloaded 213 times
Re: Slow to open and to work
This drawing should be no problem to handle (<1sec to load, save, etc.).
In the later case, you can find a tutorial on our website at:
There are settings that can affect display performance. However, I cannot think of any setting that would slow down saving or loading. Is the file saved on a local disk or on a network or cloud drive or similar?
You also might want to make sure that your computer is not generally busy doing something else. You can use Windows Task Manager to do that.
Does that mean you succeed in resetting your QCAD configuration and it didn't help or that you had no luck resetting the configuration?
Thank you Andrew,
I originaly thought that this file was linked in some manners to other files on the server but I have copied the folder he was in so ...
I suppose I miss something in the reset routine, I will check it one more time.
Have anice day
Have anice day
