QCAD will not run after install
scottd49
Post by scottd49 » Wed Apr 26, 2023 2:33 pm
I purchased QCAD Pro version 3.28.1. Installed on 64 bit operating system x 64-based processor using windows 10 ver 22H2. After install program will not run. I am running program as administrator and I continue getting this message--"windows can not access the specified device, path, or file. Any help will be appreciated.
Re: QCAD will not run after install
Post by andrew » Wed Apr 26, 2023 2:39 pm
I'd recommend to reinstall and check the permissions of the QCAD folder and application.
Please refer also to:
https://support.microsoft.com/en-us/top ... 5d3cc29657
