[solved] Unable to install new QCAD version (3.29)
amelie
Post by amelie » Fri Feb 09, 2024 3:54 pm
I can't install version pro 3.29 on xubuntu 22.04
Here is the error message:
QCAD version 3.29.3
QScriptEngine: Must construct a Q(Core)Application before a QScriptEngine
./qcad : ligne 13 : 6453 Abandon (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=0 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
Please use the offscreen or minimal platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
I tried with the different packages...
Thanks for your help!
Amélie
Re: Unable to install new QCAD version (3.29)
Post by CVH » Fri Feb 09, 2024 7:40 pm
Not a specialist on this matter ... :wink:
Similar reports where usually solved by opting for Qt 5:
https://www.qcad.org/rsforum/viewtopic. ... 473#p42471
You probably need Wayland support
You can also test a fix based on a startup switch (Again Wayland related):
https://www.qcad.org/rsforum/viewtopic. ... 467#p43468
That is all that pops up recently.
Best is to wipe other failed trials ... 3.29.4 is the latest release.
amelie
Post by amelie » Fri Feb 16, 2024 3:30 pm
I succeed by deleting old configuration files as describe here : https://qcad.org/en/tutorial-resetting- ... ion#Linux
Delete the file ~/.config/QCAD/QCAD3.conf
To reset the library browser, delete also the file ~/.config/QCAD/library_3_0_0_9.db
Start QCAD
Thanks a lot for your answer CVH!
Amélie
Post by CVH » Fri Feb 16, 2024 3:46 pm
Glad it worked out. :P
Not that resetting the configuration was in my reply or that it should affect installing/updating.
So basically you solved it yourself.
Please edit the title of your initial post to reflect that by adding "[SOLVED]"
