[solved] QCADCAM 3.25.2-64 will not finish opening after install
mqbeers911
Post by mqbeers911 » Sun Sep 27, 2020 8:14 pm
Got a new computer and the first one with Linux. Computer had trial version on QCADCAM on it and I liked it so purchased the latest version in the store - QCADCAM 3.25.2_64. My system is running Ubuntu 18.04 and I know it is 64 bit.
After installing the .run file (Check file run as program, launch the .run file, followed the instructions in Terminal.) Everything seemed to go well with the install but when I click on the program to start it it gets to 99% and just hangs there. I can close it and it does not hang up the computer but will not load. Message at the lower left is:
Initializing add-ons: 99%
Report Bug
Any help out there for this? I assumed that since the Trial version ran flawlessly that the production version should do the same and that the required system libraries are there. Since I do not know what system libraries are needed, and there is no help for this in the install/troubleshooting section on the website, I would appreciate some help.
Re: QCADCAM 3.25.2-64 will not finish opening after install
Post by andrew » Sun Sep 27, 2020 8:21 pm
Please remove the file plugins/libqcadgles3d.so
It seems to be an incompatibility with the newer version of Qt this package uses and the OpenGL setup of some Linux distributions.
mqbeers911
Post by mqbeers911 » Sun Sep 27, 2020 9:59 pm
Thank you andrew. That did it. Appreciate the quick response. :)
charlie_fd
Re: [solved] QCADCAM 3.25.2-64 will not finish opening after install
Post by charlie_fd » Mon Oct 26, 2020 1:18 pm
I've had similar issues on Fedora 32. Removing the plugin worked for me too.
Here's the output of the console with the plugin:
$ opt/qcadcam-3.25.2-pro-linux-x86_64/qcad
QCAD version  3.25.2
Warning:  RPropertyTypeId::generateId: property already initialized:  7RObject : "" : "Invisible"
12:03:58: Debug:    RGLES3DPlugin::initScriptExtensions
Warning:  QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Warning:  QOpenGLWidget: Failed to create context
12:04:01: Debug:    RGLES3DPlugin::initScriptExtensions
Warning:  composeAndFlush: makeCurrent() failed
Some info about running system (showing that GLX should be enabled):
$ glxinfo -B
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Intel (0x8086)
    Device: Mesa Intel(R) HD Graphics 520 (SKL GT2) (0x1916)
    Version: 20.1.10
    Accelerated: yes
    Video memory: 3072MB
    Unified memory: yes
    Preferred profile: core (0x1)
    Max core profile version: 4.6
    Max compat profile version: 4.6
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) HD Graphics 520 (SKL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.1.10
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.1.10
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.1.10
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
